| Posted by Stephen Jones on May 04, 19100 at 21:28:44: | |
| In response to Re: Moving a Shower Drain | |
Brian: You might try raising the shower onto a platform, allowing enough height to plumb the new drain onto the old (I've had to do this once), or if that is not an option, I think I'd recommend either learning to use a masonry saw to cut out the concrete, or maybe learn how to do tile. I've done tile for quite a while, and it's really not that hard. Your local building store can give you plenty of advice, and provide you with all the materials you'll need (Lowe's Home Depot. etc.) :�)
: Thanks In Advance, : Brian
| There are none. |
