Re: Water leaks out from under my Toto CST 874 toilet
Posted by Terry Love on May 04, 19100 at 02:54:20:
In response to Re: Water leaks out from under my Toto CST 874 toilet
: A few months ago I got a Toto one piece toilet and it seemed to work well. Lately the flush got slow and now it leaks from under the toilet when flushed. I took the toilet off and poured a 2 liter bottle of H20 down the plastic adaptor that goes to the drain and it went down without problems. Could the problem be the wax ring or the black rubber collar that the Toto hooks up to on the plastic adaptor? Dave, I would replace the wax ring under the Unifit adapter. There should be sufficent wax to seal from top to bottom. You could also check the black rubber collar for cuts. You may also use a small mirror to see if there is anything in the trapway. I have pulled many things out of various toilets over the years. Everything from kids toys to make-up kits. Terry
