Re: outside water lines
Posted by hj on May 03, 19100 at 23:32:55:
In response to Re: outside water lines
If this is the pool wter piping, not the makeup fill line, then copper is the worst material. The chemicals will erode it and you should have green areas in the pool. PVC is the proper material for swimming pools and lawn sprinkler systems.
: Water lines I have running outside to my pool is the heavy grade copper piping. It has sprong a leak every where. What's the best material to use for outside water lines?
Replies to this post
There are none.
