Re: Low water level in toilet bowl...
Posted by hj on May 03, 19100 at 01:07:45:
In response to Re: Low water level in toilet bowl...
Most of the new bowls do have a very low water level. To find out if yours is one of them, slowly pour water into the bowl. If the water level essentially stays the same, then there is nothing you can do to raise the level. If, however, it does come up, then the small refill tube from the fill valve to the overflow pipe is not sending enough water to the bowl after a flush.
: Hi everyone! I'm a newbie to the whole home scene, so please excuse me if this question is a bit trivial. My wife and I recently moved into a new condo. There are two bathrooms in the place...one on the first floor and one on the second floor. The levels of both toilets seems awful low and are having difficulty getting everything down with a single flush (not to mention marking the bowl).
: Is there anything I can do to raise the water level in the bowl...or get it to flush better without having to spend big bucks? Offhand, I don't know the model...sorry. Any help is GREATLY appreciated! :)
Replies to this post
There are none.
