Re: Boosting water pressure
Posted by hj on May 02, 19100 at 10:14:27:
In response to Re: Boosting water pressure
The only solutions, if your analysis is correct, are a bigger pump or a larger storage tank. The pump is a solution only if the well is able to supply more water.
: I live in the country and our water is supplied by a well. After you run the shower a bit, the water pressure drops off. What I think is the pump is not keeping up with the demand. Its pressure is set at 30psi kick-in and 60psi shut-off. How can this be remedied,.?
: either at the shower head or the whole system?
: I await your expert input.
: Thanks,
: Tom
Replies to this post
There are none.
