| Posted by hj on May 02, 19100 at 09:42:34: | |
| In response to Re: stabilising shower temperature | |
You may need a pressure balanced valve to control the pressure differentials, and also a thermostatic valve to maintain the desired temperature. : we have a shower fed by a pressure activated pump which supplies cold direct to shower and cold to pressure activated gas geyser to give the hot. The result is unstable water temperature because cold supply pressure varies differently from hot supply.
| There are none. |
