| Posted by hj on May 02, 19100 at 02:01:08: | |
| In response to Re: 4 Bolts for Toilet | |
That is a really old toilet, or it is a 10 inch rough model. I always used dummy bolts in those holes, but they were intended to have screws inserted to keep it from twisting on the floor. : I installed an old American Standard 13 litre toilet in my rennovated basement bathroom, and found that there are 4 bolt holes in the base. Of course, only 2 line up with the new flange. : I have noted installations of similar toilets, and see that they indeed have 4 bolts installed. Were the front two just for additional stability and to reduce possible twisting stress on the flange? I only used the rear bolts with the flange. : I'm going to replace the toilet soon with a low volume model, but am curious none the less. It seems to work fine and is quite sturdy with just the 2 bolts.
| There are none. |
