Re: New tub won't drain
Posted by Terry Love on August 13, 1998 at 15:02:25:
In response to Re: New tub won't drain
If the water came "crashing out" when you made the connection to the main drain, I would suspect the main drain. Many times on tub installations, I will snake out the drain before I install the p-trap to determine if the drain line has any problems before I close everything up.
Replies to this post
There are none.
