| Posted by hj on April 29, 19100 at 09:30:15: | |
| In response to Re: New house, low water pressure | |
You can install a packaged pump/tank system to increase the pressure. Install it side arm style with a check valve on the main line so that the pump only supplies your water if the main line's pressure is too low. : I just had a house built in a community with it's own water and sewer facilities that were built in the early '70s. Unfortunatly the water pressure is low. As far as I can tell it is like that throughout the whole community. Is there a way to increase the pressure in the house, particularly for the outside spigots.
| There are none. |
