| Posted by Tank on April 28, 19100 at 22:38:49: | |
| In response to Re: 53 1/2 inch bath tub | |
: Hi again Tank, : : Thanks for answering my post about the 53 1/2 inch bath tub. You are correct in suggesting that my cracked tub might, in fact, be a 54 inch tub that measures slightly short. I found out that the original size of this tub was listed as 54 X 40, so the UR tub you suggested sounds fine. Coincidently, Universal Rundle is manufactured right here in my home town in Iowa, but the factory does not sell retail. I think the "Lawton", though narrower than my present tub, would work nicely, but I have not found a local retailer with a UR catalog. Where did you buy your tub? If you have any installation tips that might save me a headache, I would be happy to accept them. : : Thanks again for the help. This is the first time I have posted a message on a non-computer related message board and I am very pleased that you were here to help me. : : Probably most plumbing houses in your area will carry UR, : 54" is no longer a real common size tub, but when searching I found several manufacturers making them. : Make sure you get the drain on the correct side! : Note that tubs come in different widths. : The Lawton dimensions are available as a web page or : The surround I am using is a universal fit plastic model. : I think UR does make a matching surround, maybe another $150 or so? : Make sure you level the tub. : Last, stuff the tub-to-wall cavities with fiberglass insulation and your tub will stay warm much longer. : There are more mobile homes per capita in South Carolina than any other state :-( : Glad to be of help. : Good health, Weogo Weogo, you mentioned that, although 54 inch tubs are hard to find, you found several manufacturers that make them. Could you list a few? The only 54 inch tub I have found is the UR tub. I would like to find a 54 X 40 if I can. Thanks again, Tank
