| Posted by Tank on April 28, 19100 at 20:48:44: | |
| In response to Re: 53 1/2 inch bath tub | |
: Hi Tank, : : i'm working on a house that started out as a mobile home. It has a cracked bathtub. Does anyone know of a manufacturer that still makes a 53 1/2 inch bathtub? The shortest I have been able to find is 54 inches which would necessitate moving a wall. : : tank@willinet.net : Check the actual dimensions on the 54" tubs that are available. : I'm installing a fiberglass 54" Universal-Rundle 'Lawton' that measures 53 7/8" : Can you power-plane the wall studs down a bit for clearance? : Good health, Weogo Weogo Reed, Thanks for answering my post about the 53 1/2 inch bath tub. You are correct in suggesting that my cracked tub might, in fact, be a 54 inch tub that measures slightly short. I found out that the original size of this tub was listed as 54 X 40, so the UR tub you suggested sounds fine. Coincidently, Universal Rundle is manufactured right here in my home town in Iowa, but the factory does not sell retail. I think the "Lawton", though narrower than my present tub, would work nicely, but I have not found a local retailer with a UR catalog. Where did you buy your tub? If you have any installation tips that might save me a headache, I would be happy to accept them. Thanks again for the help. This is the first time I have posted a message on a non-computer related message board and I am very pleased that you were here to help me. Cheers, Tank |
