| Posted by Terry Love on August 13, 1998 at 14:43:43: | |
| In response to Re: replacing bathtub with shower in a mobile home | |
I believe you will need to build a shower within the mobil home. The one piece units require a wall to be removed. By the time the unit is in place, all savings are gone. Determine the size pan that will work. Some standard sixes are: 60x32, 54x34. 48x34 Walls can be done using laminate, cultured marble, or tile. You may even find some water resistant paneling that may work for a shower somewhere. This would be a good time to replace the shower faucet with a pressure balanced one. More older people are injured by hot water than young people. Consider installing blocking or support in the walls for future grab bars. Terry |
| There are none. |
