| Posted by hj on April 26, 19100 at 00:31:23: | |
| In response to Re: solder containing flux | |
No. Unless you are using something like the flux/solder paste, the flux must be applied to the pipe and fitting before they are heated. And even with the combination paste, you still need to use solid core solder. : When soldering copper pipe - can you use solder that contains flux?
| There are none. |
