| Posted by Dave on April 25, 19100 at 10:29:28: | |
| In response to Re: Gerber Toilets: Special Gasket? | |
: : Does anyone know if Gerber toilets require a "special" tank-to-bowl gasket? I recently replace the flush valve and, therefore, the gasket. The HW store had 2 kinds and I got both. Both leak like a seive. I put the old one back and it worked, but had a small leak (probably induced when I removed it or because of age). I can't tell by looking if the old one is significantly different from the new ones I bought. : : Thanks in advance! : Dave, Gerber close couple gaskets are "Special" I handle 4 different gaskets for the gerber depending on the model. If you can find what model toilet you have I'll give you the proper gerber number and you may be able to find it a gerber dealer near you. : Scott Scott, Thanks again! |
| There are none. |
