Re: Cast-iron tub replace or retile
Posted by hj on April 25, 19100 at 02:35:59:
In response to Re: Cast-iron tub replace or retile
If the tub is in good condition, just replace the tile, otherwise replace the tub and tile. Donot use a tub insert. They are a last ditch effort when the user does not want to replace the tub. After a while you can have a different set of problems with them and then you may still have to do the replacement.
: I have a bathroom with a nice sturdy cast-iron tub but the thin-set tile above the tub is shot and lets
: water leak to the first floor. Is it more of a hassel to replace the whole thing, or to pull the tile and be
: careful not to damage any of the tub? If I replace it they want a fiberglass insert tub.
: Any help is appreciated.
: Thanks in advance.
Replies to this post
There are none.
