Re: Very Slow Leak at Pipe Joints
Posted by Kathy on April 23, 19100 at 22:32:54:
In response to Re: Very Slow Leak at Pipe Joints
I have a feeling I did not explain my plan clearly enough. What I am planning to do is just to apply plumber's glue to the outside of the pipe joints to stop the leak. I do not want to take anything apart at all. At least not for now while the leak is minimal. I am just not sure if the glue can take the constant pressure of the water as it will try to break thru the glue at the leak. I know it is not the best plan, am just wondering if it is a good solution at all. Like I said before, the leak is very-very minimal, a drop or two every other day or so. I have coppper pipes and it looks like the joints are screwed together. Thanks so much for your help!
Replies to this post
There are none. |
