| Posted by Frank Braunlich on April 23, 19100 at 15:32:45: | |
| In response to Re: Septic Drain Field Pipe | |
: One of the pressurized drainfield pipes that protrudes out of the ground was clipped by a lawnmower : and broke off just above the elbow at the base of the drain field. Is there any way to get the remainder : of the plastic pipe out of the elbow without digging down and cutting off the elbow and replacing it? When : I do replace the upright schedule 40 pipe, can I use regular PVC cement? Thanks.
| There are none. |
