Actually it is only 25' to the main "line" sewer drain
Posted by Mark on April 22, 19100 at 18:05:07:
In response to Actually it is only 25' to the main "line" sewer drain
: Hi : I need help with a problem with galvanized steel kitchen sink drain. I have just bought this houes about 50 : years old. The kitchen sink drain system is galvanized steel. It runs from the ptrap at least ************25'***********to the main : sewage drain. It is rusted, but I may be able to clean it out. Should I just replace the drainage system : with abs or should I just snake this line to remove debris. If I do this will it hold up? : Thank you very much in advance!! : Mark Arroyo
