Long galvanized steel kitchen sink drain rusted
Posted by Mark on April 22, 19100 at 14:10:28:
Hi I need help with a problem with galvanized steel kitchen sink drain. I have just bought this houes about 50 years old. The kitchen sink drain system is galvanized steel. It runs from the ptrap at least 50' to the main sewage drain. It is rusted, but I may be able to clean it out. Should I just replace the drainage system with abs or should I just snake this line to remove debris. If I do this will it hold up? Thank you very much in advance!! Mark Arroyo
