| Posted by Dave Hino on April 21, 19100 at 13:14:27: | |
What is the best way to solve my toilet flange delema. I have 4" service weight (SV) cast iron waste plumbing. I am remodeling my bathroom. Was forced to really due to leaky toilet flange and ruined subfloor. All of this is due to the previous owners attempts at resolving a simular problem years ago. AllThe existing plumbing exists as follows: From a 45 deg Y on the main stack a short peice of 4" cast (9 inches) extends to a 45 deg bend with a hub or "bell" at the top. In the bell was a leaded in pipe with a lead sleeve to which a brass flange was soldered. The lead sleeve is ruined and the brass flange is removed now. I have a section of the floor removed and have access from below.Is there a way to convert to plastic? Are there toliet flanges available that fit into a cast iron hub if I can get the old stuff out of the hub?
| There are none. |
