| Posted by George Benham on August 10, 1998 at 11:11:30: | |
I have a shower/bath that has three knobs Hot, Cold, Divertor. When you try to divert the water from the bath to the shower half of the water continues to run to the bath, making the shower pressure very weak. I have removed the knob and the stem nut and gently (as not to break anything) tried to screw out and also pull straight out the stem, to no avail. I figure there are lime deposits on the inside of this divertor. Would it be possible for you to instruct me on the proper technique on removing the divertor so that I can proceed with confidence. That way if I still break something I will know that I was at least using the right technique. Thank you for you assistance |
