| Posted by hj on April 19, 19100 at 00:01:14: | |
| In response to Re: Specs for Irragation system pump | |
You should design the lawn irrigation system first and then provide a pump that will supply its needs. While designing it, you should also consider the potential pumps that are available within your budget. It is sort of a catch 22, since one will affect the other. : Anyone have some suggestions for a pump for an lawn irragation system. I would like to pump out of my pond. I don't need much suction lift. I have approximately 3600 sq ft of lawn. I would like to know typical gpm and pressure requirements for a lawn sprinkler system. : Thanks in aadvance. : -Curt
