Re: toilet
Posted by hj on April 18, 19100 at 02:17:05:
In response to Re: toilet
If the toilet is sitting on the flange, then you have a larger problem. If this is the case, then the wax ring is being squeezed out from beneath the toilet and there is no seal left.
: I replaced my bathroom floor and installed a new American Standard toilet. My problem is that the new floor is about 3/8" lower than the old floor so I can't get the toilet level and secure on the floor. It is about by about 1/4". Can I use shims to level it out? It is water tight and works ok but I shut the water off until I figure out what to do. The closet flange sticks up above the new floor so I think this is what is causing my problem.
Replies to this post
There are none.
