Sewage ejection pump
Posted by Greg on April 17, 19100 at 12:23:18:
I installed a sewage ejection pump system in my basement to move waste water from a baseroom up about 8 ft to the main drain. When the pump is done, there is a loud banging noise and kickback on the drain. I did install the a check valve and per the instructions on the pump, I drilled a 1/4 inch whole in the drain pipe just above the pump. What can I do to end the nosie?
Replies to this post
