Re: Hot water heater
Posted by brian on April 17, 19100 at 10:52:58:
In response to Re: Hot water heater
: An above normal amount of hot water is running out of the safety-valve discharge pipe which runs from the hot water heater to the outside of the house. It is dripping enough to maintain a small puddle outside the house. Thank you in advance for the advice.
you should not have any water coming out of this valve at all. it is a temperature, pressure valve. your water heater may be overheating and may need a new thermostat or your pressure has gone up at the home and you will need to install a pressure regulator. the pressure should be under 80lbs. or... if you are lucky it is just a faulty t&p valve and you will need to replace it regardless.
Replies to this post
There are none.
