| Posted by elliot on April 14, 19100 at 01:21:40: | |
| In response to Re: Leaking shower | |
no, no, no, all you have to do is remove a couple of tiles around the shower handle with a hammer and take a peek inside, if you dont see anything then put a garden hose up the drain, if that dont seem to do the trick then shove a little packing up into the female end of the hot side stem and give it a whirl, yea thats it. : is a slow leak which drips down or follows the pipes and ends in the basement. The shower has ceramic tiles which the grout and tiles look okay. The drain in the middle of the shower which also looks fine. How do I locate the leak and stop it? Any suggestions?
| There are none. |
