| Posted by hj on April 11, 19100 at 23:42:04: | |
| In response to Re: Copper/Brass corrosion | |
It is called pipe joint compound, (pipe dope), and tightening the connection. Copper to brass does not corrode unless it is leaking. : I'm getting corrosion from my copper to brass nipple connections. I've heard of copper to galvanized corrosion and the use of dieletric unions to prevent that problem. : Is there anything similar that can be done to prevent copper to brass corrosion?
| There are none. |
