Gerber kitchen faucet
Posted by ed bushey on April 09, 19100 at 15:23:05:
We purchased a kitchen faucet in December.1999. It is a Gerber faucet with a removable nozzel with incorporated spray. The water flow from the faucet is very slow. The flow from the replaced faucet was quite adequate. I installed the new faucet using 3/8 inch metal braided lines. I removed the removal faucet end from the supply hose and checked the flow from the hose only. This flow was also found to be very low. The faucet diagram show a "check/flow restricter" in line. Could this be the problem and if so, what can I do about it.
Replies to this post
There are none.
