Re: Toilet Flange Install
Posted by hj on April 05, 19100 at 09:58:46:
In response to Re: Toilet Flange Install
You can do either. Sometimes it is easier to cut the pipe first so you do not have to slide the flange down the excess pipe.
: One more minor clarification...
: I have a 3" toilet drain extending 3-4" above the plywood subfloor. I am installing 1x1" mosaic ceramic tile. Do I cut the drain down to the plywood, flush with the tile, or do I install the tile and flange first, and THEN cut the drain pipe down flush with the flange???
: ARGH! So close to finishing...
Replies to this post
There are none.
