| Posted by hj on April 03, 19100 at 04:17:02: | |
| In response to Re: gas supply to pool heater | |
A trail rider preacher arrived in a western town to hold a revival meeting, but on the designated day, there was a terrific blizzard. Just one lonely cowpoke showed up for the meeting, so the preacher told him that they might as well cancel it. The cowboy said, "Preacher, if I had to feed my cattle, and only one cow showed up, I would still feed her." So the minister got up and gave his best Fire and Brimstone sermon. Afterwards he met the cowboy at the door and asked how he enjoyed the sermon. The cowboy replied, "I would feed the one cow, but I wouldn't give her the whole wagonful." Dale is giving you the whole wagon full, when all you want is one mouthful. The pipe can, and probably should, go between the joists. The depth, and material, is regulated by your plumbing inspection department, but is at least 12" deep. If you use the green pipe, I would wrap it completely with the protective tape, which you have to use on fittings and damaged areas of the pipe anyway. You can provide a barbeque opening as long as you size the pipes properly.
| There are none. |
