WELL ABOUT THE NOISE FIRST OF ALL HOW OLD IS THE HOUSE ??? 2ND WAS THIS BATHROOM DONE BY A PROFESSIONAL PLUMBER OR A HANDY MAN ??? IF A PLUMBER DID IT AND A PERMIT WAS PULLED THEN MOST LIKELY THE JOB WAS DONE CORRECTLY! YOU COULD HAVE A PARTIAL BLOCKAGE IN THE VENT WHICH IS CAUSING THE WATER TO BE SUCKED OUT OF THE TRAP DOES THIS HAPPEN IN THE SINK??? WHAT YOU COULD TRY IS THIS LOOK DOWN THE STRAINER OF THE SHOWER STALL WITH A FLASHLIGHT HAVE SOMEONE FLUSH THE TOILET SEE IF THE WATER LOOKS LIKE IT'S BEING SUCKED OUT OF THE TRAP OR IF IT'S JUMPING UP AND DOWN IF IT IS MOST LIKELY THE VENT MIGHT HAVE A CLOG IN IT YOU CAN DO THE SAME TO THE SINK ALSO IF THIS IS THE CASE YOU CAN CONTACT YOUR LOCAL PLUMBER OR DRAIN CLEANING SERVICE AND HAVE THEM SEND A SNAKE DOWN FROM THE ROOF IF A HANDY MAN DID IT OR HOMEOWNER THERE IS PROBABLY NO VENT FOR THE SHOWER OR THEY DID IT WRONG GOOD LUCK
