| Posted by hj on March 31, 19100 at 07:54:20: | |
| In response to Re: Qwik Jon | |
If you look at a picture of one, you will see that all the water has to enter them at a higher level, usually into the top of the receptor. This is fine for toilets and wash basins, but the bottom of a tub would have to raised above the level of the pump basin in order to work properly. : I would like to build a below grade bathroom. Will either the # 100 or #102 handle an oversize bathtub as well as toilet and lav. Also do these pumps require constant water pressure--- I have a well. Thanks RR
