Re: Replace toilet ?
Posted by Terry Love on March 29, 19100 at 13:40:16:
In response to Re: Replace toilet ?
: I have a toilet that has cracks in its bowl.It also seeps water at the base and holds very little water in the bowl.I think it best to replace it but,because this is a summer cottage all plumbing must be drained.If I could get some advice on a type that would work well in this application and any tips on winterizing it.Thank you.(plumbing is pvc and copper)
If the toilet is cracked, it should be replaced. Check out the toilets on the Toilet report. To Winterize, you will want to sponge out the water in the tank, and fill the bowl with non-freezing solution. Terry
Replies to this post
There are none.
