| Posted by hj on March 29, 19100 at 09:11:37: | |
| In response to Re: How to build stairs | |
You to divide the run and rise by what is available and use those dimensions to make the stringer. If you try to make the steps 10" by 10" then you would have to lower the upper floor to a point 8'-4" above the lower level, assuming you count the upper floor as one of the steps. : How do you build stairs? My run is 105 and my run is 105. I've been told I have to have 10 steps with a 10" platform and a 10"rise. That's great but how do you figure out how to make the stringer and then put it together from that point?
| There are none. |
