Re: Toilet intake valve
Posted by hj on March 28, 19100 at 23:33:26:
In response to Re: Toilet intake valve
The fill valve's stem may have a crack in it, in which case repairing the shut off portion would not solve the problem. Change the fill valve. (and the lower flapper).
: I have a Mansfield toilet intake valve that keeps running, even after the tank is filled up. I went to the hardware store and purchased a new LASCO toilet valve kit with replacement black rubber bladders and brass screws. But once I had installed these, the problem persisted. Have I installed them incorrectly, or do you have any other suggestions. (The diagram on the replacement parts kit was too tiny to read). Thanks for any suggestions.
Replies to this post
There are none.
