| Posted by kris on March 27, 19100 at 15:19:56: | |
Problem: #1. low water pressure. #2. I can pull the adjusting screw in the pressure regulator out by hand. The internal threads in the regulator are rusted out. I have no idea what brand it is, so replacement parts are out. Should I try and rethread the "bonnet" with a larger diameter and then use a larger set screw, or change the regulator. |
