Re: Solenoid valve to turn on and shut off 1/2" water line?
Posted by BB Electronics Service on March 25, 19100 at 10:38:31:
In response to Re: Solenoid valve to turn on and shut off 1/2" water line?
: I am trying to find a solenoid valve that I can attach to an electrical switch to basicall turn on or off a 1/2" water line. Where can I find such a thing (local plumbing supply house said they never heard of such a thing...) We have in stock 1/2" water solenoid valves. To order one you have to provide the following info. Is the water line 1/2" copper,PVC or galv pipe? Do you want the solenoid valve to be operated by 110 volt ac? Will the valve be energized for long periods of time? Will the water line have hot or cold water? Let us know the above info and we will quote you on a standard water solenoid valve.
