Re: Gas, Water and Electricity on a single trench?
Posted by Ray on March 23, 19100 at 17:02:27:
In response to Re: Gas, Water and Electricity on a single trench?
: : I'm in the process of Installing a new gas line for a spa heater. Can I lay also a water line and electrical (PVC's) on the same trench? Or this is a code violation.
: : Thanks in advance.
: George,You need to check with your local code officials that pertain to your area. The water needs to be 1' below frost level, the gas needs to be a mim of 12-18" under ground depending on what material you use and the slectric needs to be 24" below ground. Dale's Plumbing Service Inc LMP
So, If I put the Elctrical PVC at 24" then the Waterline (PVC) at 18" and gas line at 16"
below the ground on the same trench would be feasable? I live in Southern California.
Thanks for your assistance.
Replies to this post
There are none.
