Re: Gas, Water and Electricity on a single trench?
Posted by Dale's Plumbing Service Inc LMP on March 22, 19100 at 07:07:55:
In response to Re: Gas, Water and Electricity on a single trench?
: I'm in the process of Installing a new gas line for a spa heater. Can I lay also a water line and electrical (PVC's) on the same trench? Or this is a code violation. : Thanks in advance. George,You need to check with your local code officials that pertain to your area. The water needs to be 1' below frost level, the gas needs to be a mim of 12-18" under ground depending on what material you use and the slectric needs to be 24" below ground. Dale's Plumbing Service Inc LMP
