| Posted by artistic marble co. lawton ok. on March 21, 19100 at 23:56:17: | |
| In response to Re: restoring cultured marble walls | |
: : I have a ten year old shower that needs to be replaced. The walls are cultured marble panels and mouldings approx. 3/8" thick. They have become dull and slightly discolored with age. Before i replace them with anouther wall system, does anyone know how to resurface them? Leo : Gel-Gloss Cleaner & polish combines the most powerful cleaning agents with the most effective carnauba waxes to produce the highest surface luster possible. : It is excellent for: Sinks, Basins, Counter Tops, Tubs, Spas, RV's, Boats, Shower Doors, Stainless Steel and Porcelain. : Recommended by major marble, fibreglass and acrylic manufacturers. artistic marble re: the white spots and the yellow you see are mostly in the gel coat and gel gloss wont fix even a buffer and compound wont get it out alot of co's use different gelcoats some last longer some dont, replacing would be your best bet and when you do make shure they are using 66-36 clear gelcoat ............. |
| There are none. |
