| Posted by Michael D. Gianneschi on March 20, 19100 at 10:36:00: | |
I have a plastic pipe that is leaking from under the toilet in the guest bathroom. From the basement you can see the three inch pipe connection up to the coller going to the toilet. The leak is at the junction of that coller. what can I do to stop the leak. Can I put some kind of glue/sealer up in the joint? I'm afraid that it wont get up into the joint. Also the toilet has a small amount of water around the base , I replaced the wax gasket of the toilet could it be a bad toilet? |
