| Posted by Dale's Plumbing Service Inc LMP on March 19, 19100 at 16:02:38: | |
| In response to Re: New single handle fitchen tap, no cold water in pipe knobb turn eight and leaks HELP. | |
: I bought a new set of kitchen taps, old set had spout and hot and cold taps. : They have been turned off since Dec, l bought new taps that have center tap. : When l turn it the right pipe below has hot water coming out. : When l turn it for the cold water, just small drips of water, copper pipe, : below sink has no water coming out. : And the new taps leak as l turn the knob for hot water comes out of the bending tap area. : Could the cylinder in nrw taps be loose, l did for get plimbers tape in threads, could that be it? : And for no cold water coming out of the pipe below the sink, could the shut off valve be clogged, : or the cold water pipe, please help. CMHC were to fix items in house so since Dec have had : no kitchen sink water from taps, should l call plumber or can you help. : Yours Truly James James, |
| There are none. |
