Re: Water proof sheetrock
Posted by Dale's Plumbing Service Inc LMP on March 19, 19100 at 15:57:23:
In response to Re: Water proof sheetrock
: I've noticed that a brown stain is beginning to leach through the chaulking along the tub. I am going to assume that the sheetrock behind the tile is wet due to water seepage. Would it be possible to remove a section of the tile, install waterproof sheetrock to the affected area? Sarah, It is possible to do this but once you start you may replace more than you were intending to do in the first place. This may require someone experienced in tile and sheet rock repair.Dale's Plumbing Service Inc LMP
Replies to this post
There are none. |
