Re: Cold water coming out HOT
Posted by wayne josey on March 18, 19100 at 02:22:21:
In response to Re: Cold water coming out HOT
: The circulating system is the problem. Somewhere the hot and cold pipes are close together and since the hot water lines are always hot, the heat transfers to a portion of the cold water and that has to be run out when you open the faucet.
: : We are in a new house and when you first use the cold water, it comes out really hot for about 30 seconds, then turns to cold. As a side note, we also have recirculating hot water, if this could be a factor.
: : Any ideas?
Could possibly have a leak or a split in a high pressure line somewhere. Have your water bills been high lately?
Replies to this post
There are none.
