Re: low hot water pressure at tub spout....
Posted by Bobby on March 16, 19100 at 18:04:57:
In response to Re: low hot water pressure at tub spout....
You may have "integral stops" on your shower valve and one is not opened all the way. Take the trim off of the shower valve and see if you see screwdriver stops just inside the piping on the valve. If so, open the screw up all the way. It's not uncommon in homes for valves to not have stops, so if you don't see them, you don't have them. You have a different problem
Replies to this post
There are none.
