| Posted by hj on March 16, 19100 at 00:41:06: | |
| In response to Re: insulating pipes | |
Cast iron because of its greater mass is much quieter than PVC or ABS. If you are insulating for noise, then any deadener will work Just use the most you can apply around the pipe. : What is the best way to decrease the noise of water flow in pipes? Is there a difference in cast iron and PVC re. noise in drain pipes? What is the best insulating material? Thank you, Connie
| There are none. |
