| Posted by Ben Bracker on March 14, 19100 at 15:34:10: | |
| In response to Re: WATER PRESSURE OUT OF WACK!!! | |
: WHEN WATER IS IN USE, THE PRESSURE GAUGE'S NEEDLE GOES UP AND DOWN THE DIAL AND THE WATER PRESSURE GOES FROM HIGH TO LOW. I DON'T KNOW IF IT IS THE TANK OR JUST THE CONTROL DEVICE, PLEASE OFFER ANY ADVICE. THANKS. It sounds like you have a water logged pressure tank. If its a captive air type tank its bladder could be broken. If it is a captive air type tank at bracker.net's help pages there is information on how to check same and/or air the tank. You will do so at your own risk, but its the best I know of that can be offered at this time. If you have other questions you may e-mail me. Ben
| There are none. |
