| Posted by David Vasari on March 14, 19100 at 08:38:19: | |
| In response to Re: shower drain odor....is this dangerous? | |
: David, there is no overflo in a shower. Only in a lav and a tub. I use a drain cleaner called thrift to clean the drain and it has its own bateria that helps to keep it clean. There are home remidies that clean drain lines also. Dale's Plumbing Service LMP Thanks. I tried your advice and it WORKED. |
| There are none. |
