| Posted by MitchG on March 14, 19100 at 00:10:53: | |
| In response to Re: Got it. Thank you!! (np) | |
: : ...and I can't figure out how to do it. The faucet is a Moen, and the drain stopper is clearly attached somehow and I can't quite figure out how to get it out. I'm sure it's simple (or I HOPE it's simple). Any help is appreciated. : : -Mitch, under the lav on the drain there is a rod that the lift rod is attached to. this rod is screwed into the drain comeing out of the sink. that rod is in a hole on the end of the pop up. Dale's Plumbing Service LMP
| There are none. |
