Re: WATER PRESSURE OUT OF WACK!!!
Posted by Dale's Plumbing Service LMP on March 13, 19100 at 20:31:30:
In response to Re: WATER PRESSURE OUT OF WACK!!!
: WHEN WATER IS IN USE, THE PRESSURE GAUGE'S NEEDLE GOES UP AND DOWN THE DIAL AND THE WATER PRESSURE GOES FROM HIGH TO LOW. I DON'T KNOW IF IT IS THE TANK OR JUST THE CONTROL DEVICE, PLEASE OFFER ANY ADVICE. THANKS.
Ron, If no one has messed with the pressure switch then you may have a water logged tank. Knock on it and if it has a dull thud it is water logged. If it is a bladder type, press on the schrader valve and if water comes out it done . Dale's Plumbing Service LMP
Replies to this post
There are none.
